Gaz/rpm top mounts
kam325itouring
Post Sun Jul 21, 2013 4:17 pm
Hi all
I'm trying to fit my new top mounts they are the gaz/rpm camber ones. Problem is they don't clear the top hats can anyone shed some light on this one, if there is anyone who has fitted them.
Cheers kam
All Car Audio - Approved Alarms - HID Kits - Custom Boot Installs - All jobs considered
kam325itouring
Post Mon Jul 22, 2013 12:09 am
Nobody?
andrew_baran
Post Mon Jul 22, 2013 9:35 am
If I remember rightly they won't work with standard suspension top cups - only coilovers.
If you look at your old top mounts, they had a section that fitted into the spring top cup, and the top of the spring sat quite high up - at the top of the "cup". The camber top mounts don't have that area, and therefore don't fit...
So unfortunately your solutions are:
- Run standard top mounts and have no camber adjustment
- Buy/build some coilovers, run the camber top mounts.
kam325itouring
Post Mon Jul 22, 2013 9:44 am
andrew_baran wrote:If I remember rightly they won't work with standard suspension top cups - only coilovers.
Cheers.
Great so I've got some top mounts that are no good.
So I've got some top mounts for sale cheap. Anyone who wants to buy them off me they are brand new pm me. I only got them last week.
kam325itouring
Post Mon Jul 22, 2013 2:37 pm
Spoke to gaz they have a solution they do a spacer plate for them to accommodate the top hat. Hopefully that will sort it out. They have sent it out today will keep you guys updated.
andrew_baran
Post Mon Jul 22, 2013 4:46 pm
Glad they had a solution for you. Those camber plates are not cheap!!
kam325itouring
Post Mon Jul 22, 2013 5:23 pm
