Drastic fuel consumption
AndyTouring
Post Sun Jul 21, 2013 12:47 pm
My friend has loaned me their '91 325 auto cab which is turning out to be rather thirsty - 15mpg or less!
Idling is a bit lumpy (it has an aftermarket chip installed) but runs fine when on the move. It feels like it's running with the 'choke out'.
The temp gauge only just clears the blue sector unless it's sitting in traffic for a long time. I know this isn't necessarily a problem on the M20. The heater works fine. I don't know if this is connected to the problem.
I'm suspecting the thermostat or could it be one of the motronic sensors?
AndyS
Live each day as if it's your last because one day it will be.
Post Sun Jul 21, 2013 12:54 pm
Check the blue temperature sensor as a first port of call.
http://www.e30zone.net/e30zonewiki/inde ... emp_Sensor
AndyTouring
Post Sun Jul 21, 2013 1:29 pm
Excellent thanks.
I'll have a look at that.
AndyS
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Jul 21, 2013 1:38 pm
The blue temp sensor will be overfuelling, but if the temp gauge is low then the engine may well be running too cold. If that's the case, the blue sensor is just doing it's job. Temp gauge is driven by the brown sensor, and it would be very odd if they both incorrectly thought the engine was cold.
I'd be looking at a stuck-open thermostat too.
AndyTouring
Post Sun Jul 21, 2013 2:38 pm
I'll try the thermostat first then.
Have you got part numbers for the blue & brown sensors?
AndyS
Grrrmachine
Post Sun Jul 21, 2013 3:17 pm
There's no point replacing the sensors on a whim, especially the brown one. But if you want to throw your money away, the part numbers can be found on RealOEM or bmwfans.info.
clipper
Post Mon Jul 22, 2013 6:53 pm
At 15 mpg I'd say it was leaking TBH...
bmw9818
Post Mon Jul 22, 2013 9:35 pm
i get about 25mpg out of mine, best ive got is 75miles off £20,
