Changed the cambelt on my M20B25, when i timed it all up on the marks it turned out the camshaft was a tooth out, advanced. The car has never been quite as 'on the money' as my last 2.5 and also idled like shite from cold so i thought 'huzzah, i've found my missing horsepower!'.
Fast forward a couple of days and the car has also had another air flow meter fitted that has never had the top off, electric fan and thermostat, yaddah yaddah yaddah.
Got it back on all 4 wheels last night and went out on a 'private road' to test it.
Flat out, 118mph in 4th
It just feels flat through the revs but as the car gets 'on cam' it goes then backs off, then goes, then off all the way to the red line.
I'm gonna try and get a timing light tonight to check things over but has anyone ever known the woodruff keys in the cams to wear allowing the pulley to move ar anything?? And does anyone know what the degrees of advance/retard should be on idle, at 3000rpm or whatever?
Please help, going to the 'ring in 2 weeks!!!!!!!!! Worse, i only have til the 25th july to sort this.
Thanks in advance
Tom
