why are e30 front struts at a angle?
sweep
As above aposed to modern shit been straight..just curios
Grrrmachine
- E30 Zone Wiki / Team Member
Morat
Is that right? My car is lowered 35mm but I get the excessive wear on the inside of both rears.If the wear is on the inner edge of the tyre you've got too much toe out; outer wear is too much toe in. Too much toe in is normally a by product of aggressively lowering your car.
Grrrmachine
Might be camber wear, but a 35mm drop shouldn't wear that aggressively. The article does explain that both toe and camber contribute to inner tyre wear though.
sweep
I mean from new the legs are angled forward.
Grrrmachine
Yes, angling the strut forward is called Caster.
http://yospeed.com/wheel-alignment-expl ... aster-toe/
hazd31
castor = More grip
The more castor you have the more the inside rear wheel will lift giving you more front end grip as the back doesent push on so much
capnmchl
The increase in camber outweighs the increase in toe in on the rear, so it only really wears the inner edge.Morat wrote:Is that right? My car is lowered 35mm but I get the excessive wear on the inside of both rears.If the wear is on the inner edge of the tyre you've got too much toe out; outer wear is too much toe in. Too much toe in is normally a by product of aggressively lowering your car.
There is a big difference in the way a tyre wears due to camber and toe.
harry_p
All cars with a simple macpherson strut will have the top of the strut tilted back towards the bulkhead.sweep wrote:As above aposed to modern shit been straight..just curios
This means as the front wheel turns it tilts over, and gains more negative camber.
More castor means you can run less static camber, so you don't destroy the inner edges when cruising around on the motorway, but still have negative camber when cornering to stop the tyre rolling over and killin the outside edge when cornering hard.
A lot of modern cars will have double wishbone, or multilink suspension, and have fixed castor, but gain negative camber as the suspension compresses due to the geometry. I.e, on a double wishbone setup the upper wishbone is often shorter, so as the car rolls through a corner the upper wishbone moves through a tighter arc, pulling the top of the wheel inwards.
cheers,
harry
harry
harry_p
You what?hazd31 wrote:castor = More grip
Castor is the way the front strut is inclined, and has nothing at all to do with the rear suspension.
The only component which increases inside rear wheel lift is a rear antiroll bar.
cheers,
harry
harry
hazd31
Demlotcrew
Go karts are designed to do that because they have a fixed live axle on the rear and need to lift the inside wheel to stop understeer and are only able to do this because of the high castor angles on the front struts and no suspension (no dampers no springs).
The clio is a bad example as cocking any wheel on a car will result in less grip. Especially true for a RWD car.
