86 25i fuel pipe layout,
frenchi
Post Fri Jul 12, 2013 2:40 pm
if I put fuel line from filter to regulator ,its a no go,,but if I connect from filter to fuel rail she runs after a while it seems fuel drops back it then needs cranking a bit is there a fuel layout for a high compression pre face ,its now in a face lift 89
Post Fri Jul 12, 2013 6:27 pm
Or, to put it another way, if you connect the pipes the wrong way around it doesn't run, then, when you connect them correctly, it does run. Sounds right to me!
frenchi
Post Fri Jul 12, 2013 7:59 pm
thanks brian I was told that it was right ....not,,,,,,
