hi i hve a cabby 318i and out of the blue i have started to get a whining noise each time i turn the power steering which goes up with the engine revs.
could it be fluid level?
any ideas -thanx
power steering noise
Power steering belt maybe...I had a screeching noise when turned to full lock changed the belt and fluid sorted it out but I would try the fluid first because its quicker and easier.
Have you checked the fluid level?
milescook
- Contact:
The above as well as the quality of the fluid. If it hasn't been changed as regular as it should, it certainly won't help. If its completely black then that's a sign its old fluid. It starts off life pink usually.
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
