m20 flywheel
gromgsxr
Is there any diff types of flywheels for the m20b25? Eg pre and post facelift ect? Apart from the one that has the sensors in the gearbox.
Grrrmachine
- E30 Zone Wiki / Team Member
gromgsxr
OK we'll if got a flywheel in my parts bin how can I determin what it will go on any ideas in that respect?
hongkongfuey
- Mad-tango-geezer
The preface one has a lug on the side and needs to be on early engine with gearbox sensors but will fit on early and late engines. Facelift should only be used on later engines as no sensor lug.
with cars like mine,
gromgsxr
so as long as it has no lug for the motronic 1.0 it will fit a 1990 car? dont wanna fit it and find iv got the wrong starter cus that would be a pita
hongkongfuey
- Mad-tango-geezer
if its for the later engine you can use either, its only the earlier one you need the lug on
do you need one? i have a lightened one
gromgsxr
I gather I can use either but dont they use a different starter? My car is facelift so have a face lift starter don't wanna fit a flywheeel then find I can't start car
Grrrmachine
As I said, flywheel must be matched to the starter. If your wheel doesn't have a lug, it'll be a facelift one.
