Help please : wont pass 3000rpm and jumps when you try
iceox
Post Thu Jun 06, 2013 8:20 pm
It's a 1990 325i auto
The problem is solved when I remove and put back the dip stick and oil filler cap, so does this mean they are letting air in and need replaced Or is it something else??? Cheers[/list]
Silverfang
Post Thu Jun 06, 2013 9:45 pm
Check the breather hose between the rocker cover and the intake, that can split and cause issues.
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
iceox
Post Thu Jun 06, 2013 9:54 pm
Silverfang wrote:Check the breather hose between the rocker cover and the intake, that can split and cause issues.
Cheers will do
iceox
Post Sat Jun 08, 2013 7:14 pm
any more ideas, havnt solved this yet :(
