Ride height
skoobysoo
Post Thu May 30, 2013 1:38 pm
Greetings clever people,
One of my front springs has broke, I have no idea what mm spring kit to buy as it was already lowered when I bought it. Is there anyway to work it out? I don't know what the original ride height was but I like it the height it is now. Maybe if someone with the same spec body and wheels and standard springs measured thiers would I be able to tell by the difference?
I'm a bit of a dim bird when it comes to calculations ffs.
Anyway, it's a 93' 2.5 Lux Convertible (originally a 1.8) with original standard BBSs. I do know that it had Mtec suspension as standard which is apparently lower than normal so they may even be the original springs.
Thaaaaanx! :0)
Images
COS OLD SKOOL IS SO KOOL
Big Block Events
tha881
Post Thu May 30, 2013 1:55 pm
The ride height in your pic looks lower than M-tec springs. I would safely say you can rule them out. They are dear brand new over 400 i think but can be picked up second hand for 50-100.
Eibach springs are the most widely reccomended for e30's, and i think it would offer a similar drop to how your car looks above about 35mm drop. They arent too badly priced either around 200 for a brand new set, i think they do cab specific sets aswell.
skoobysoo
Post Thu May 30, 2013 2:10 pm
Thanks for the advice, my friend who works at a Beemer garage is ordering a set for me at trade price of 75 which is nice but he wants to know 60mm or 40mm so of the 2 choices, would it be the 60s? they are the lower height right? :0/
Images
Big Block Events
tha881
Post Thu May 30, 2013 7:03 pm
60mm is the lower ride height. Cabriolet rear springs are uprated to take extra weight though so ideally you want to get a cabriolet specific spring kit
I would also get a 325i kit even if it was originally a 4 cylinder, the 325i springs will fit and will be designed for the load of that engine
