Track rod end replacement
bmw335icoupe
Post Mon May 27, 2013 9:38 pm
hello,
I need to replace one of the outer track rod ends.
The question is if I remove the inner track rod end is the power steering fluid going to poor out?
many thanks
Peter.
ajay
Post Mon May 27, 2013 9:46 pm
No it won't. The rack is sealed with the fluid on the inside of the seal.
bmw335icoupe
Post Mon May 27, 2013 9:50 pm
many thanks
Post Mon May 27, 2013 10:10 pm
bmw335icoupe wrote: The question is if I remove the inner track rod end is the power steering fluid going to poor out?
It did when I removed the boot on a rack on Saturday - but that's a sign of clapped out rack, so if there is fluid inside the boot, the rack's on its way out.
As ajay rightly says; it should all be dry in there.
