BMW e30 m20b25 turbo , ignition / coil pack / leads
shane281189
Do I need to upgrade ignition parts like leads distributor etc
s13b
A grade colder plugs would be good. Really depends what spec you're going to run in terms of mapping, turbo, cooling etc
Best option by far would be coil pack upgrade and stand alone ecu.
shane281189
It runs on mega squirt at the moment , what coil pack would I use as it has a distributor at the moment ?
ross2009
use a omega or vectra v6 coil pack,standard leads are fine but if you want to upgrade them then its up to you but as a matter of corse if there old wouldnt hurt to renew them and run it wasted spark and like s13b said run 7s resisted should be ok
