anyone know which is the correct type?
i've seen both dextron II ATF and manual box sae 80 mentioned.
i'm likely to go with the ATF if i can't find a definate answer.
318is gearbox oil
alan1272
SAE 80 is what it left the factory with. Dextron II or III can be used instead; usually to cure a box which is difficult to change gear when cold. The downside is that if the box has any rattles, they will be louder rattles with ATF.
rix313
I'm using ATF in mine.
alan1272
