baaaaaad camber or toe in
Manni198
Post Wed May 15, 2013 9:41 pm
Right my e30 cabbi has been lowered causing wheels to camber out insanely. I was looking on the net as some wheel alignment guys were telling me their are kits to allow you to adjust this. Is their anyone selling in uk and if so are they worth it wi the adjustment stay put!!!
Post Wed May 15, 2013 10:15 pm
DanThe is the man you want to contact on here, but it's simpler to just raise the car back to where in handles properly and gives a degree of comfort. I just don't get this desire to make your car look like its suspension has collapsed!
Manni198
Post Thu May 16, 2013 10:23 am
I tottaly agree I hate the ride on the car I bought it the way it was. If I do go bak to stock or close than what will o need? I think the bakk might have been lowered more than tje front also how do I find danthe?????
Post Thu May 16, 2013 1:32 pm
To get it back to stock you'll need to search out a set of OE springs - fronts to suit whatever engine you have, and rears for a cab. or touring.
If you want a little lower than standard, then the limit is about 35mm, and Eibach or H&R do quality versions of these.
Have a look at your dampers (shock absorbers) as well. The average idiot who lowers a car so far as yours appears to be either reuses the original 100,000+ mile dampers, which will have a fraction of the damping power they should have, or fits some cheap, rock hard ebay rubbish.
If the need changing, Bilstein B4 are the ones you want.
DanThe: http://www.e30zone.net/modules.php?name ... ile&u=7093
Send him a PM.
