fitting bukhead deadening
polsta
Post Wed May 08, 2013 6:30 pm
gearing up to fit the bulkhead deadening, had a good look today removed necessary bits and tried to work it all out, pretty mkuch there...only thing im not sure about is the, steering column bit ? the big round hole, how on earth do you fit that/exactly does it go, is it hard ? or if you make a cut- where do you cut it
also, is it wise to waxoyl all behind it before fitting ?
any other tips etc ?
cheers :)
jimbom30cab
Tech 1 freak
Post Wed May 08, 2013 6:44 pm
no
waxoyl stinks and the last thing you want is that behind a hot dash in the summer
imagine driving your wonderful car about with the stink of oil all the time...
use it inside the car SPARINGLY
Not sure about the deadening as i forgot to fit mine before re-fitting the dash :o:
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed May 08, 2013 7:14 pm
What sort of sound-deadening are you using? The modern type of sticky-backed bitumen mats?
polsta
Post Wed May 08, 2013 7:19 pm
no an original e30 bulkhead 1 piece deadening...
