whats this bit ? hanging inside the doors, goes over the inside of the lock obviously, but what is it ? heated locks or something ? or just part of the central locking ?
For £20 per door for a lock re-build kit,you are making a very big mistake.polsta wrote:cheers daimler, no lol no lock re building
Lock re-build kit contains all you need to build a new barrel to suit your key.polsta wrote:so is it easy to do ? on one of the locks, if looking at it from the outside, the chrome bits either side of the key slit are a bit bent , is that bit in the kit aswell ?
i also need to get a new spare key
No, its not the lock solenoid, its a micro switch that activates the dead lock feature of the central lockingJim320i wrote:Central locking solenoid
+1!Jim320i wrote:You should start a 'Polsta's Issues' thread and just keep listing new things every day
As the choirboy said to the bishop.....Jim320i wrote:I'd only do the one door as its not often your gonna be openning it on the passenger side... Plus that gets hardly any wear so just make sure its nicely lubbed up
