I did the amp drainage test today, multimeter in series between the negative battery terminal and earth lead. With nothing switched on and doors closed I got this reading, I had the meter on the 10A setting so I think this is reading 200ma. Removing fuse 28 dropped the reading to 00.9 which I believe is 90ma. Running off fuse 28 is the stereo, removing the stereo again dropped in to 0.09, so I'm assuming this is all that's running through fuse 28 whilst the ignition is off.
[/img]I know 200ma or 90ma is excessive (assuming I'm reading the meter correctly), but I also checked my daily drive Astra and found that the reading with nothing on and all doors closed was also 02.0
Can someone confirm the readings are actually 200ma and 90ma, plus I'm now thinking it could be a dud battery an the Astra is taking the same current but doesn't go flat.
[/img]
