Info required, what 16 inch steel wheel fits an E30
Neilios
Post Sun May 05, 2013 3:08 pm
As per title, I did a search and nothing came up, could anyone let me know wheat steel 16 inch wheel fits the e30.
Thanks in advance.
ranxerox
Post Sun May 05, 2013 4:14 pm
please delete
Neilios
Post Sun May 05, 2013 4:17 pm
Thanks, I was more concerned about the offset than fit as most VAG use 4x100. Looking for circa 7 inch wide but rims which will not catch the suspension etc I dont mind doing some body mods. Thansk again.
zd3bx
Post Sun May 05, 2013 4:18 pm
I think some Mini's from 2000's had 16" steelies...
The fitment is 4x100, but as far as I remember, the centre bore is a bit smaller, so you'll have to widen it to fit an E30.
EDIT: Also Renault Megane had 4x100 16" steels, but the centre bore is 60.1, so you'll need hub rings to align them to your hub. I think the ET is 36 and 43, depending on year of production.
P.S. Why would you want 16 steels anyway? lolz
ranxerox
Post Sun May 05, 2013 4:46 pm
null
miniblob
Post Mon May 06, 2013 12:02 pm
There's been few threads on this - new Mini wheels fit with spacers I believe - and I remember something about Renault wheels fitting???
Think there was talk of this when someone was finding steelies to have banded!!!
327 Touring with bass!!!
Neilios
Post Tue May 14, 2013 7:46 am
No just like the look of steel wheels on some old cars! Thanks will try our breakers to see what Mini or Megane wheels I can test.
