E30 318is - Changing front wheel bearing
E30REDD
My car sounds like an airplane when I'm turning right. I jacked up the car, spinned the left wheel and felt some vibrations in the spring, so I guess my left wheel bearing has to be changed.
I don't think my brakes are original, I think they've been replaced with 525 disks. I'm not sure though, but this shouldn't affect the the type of wheel bearing I have to buy, does it?
Can anyone recommend a place where I can buy a good and cheap front wheel bearing for my car? When replacing the wheel bearing, should I lubricate it with grease?
- **BANNED**
Front wheel bearings come as a complete hub unit,I buy mine from my local GSF.
I would be suprised if you have disc's from a 525,as I think that they have 5 wheel bolts.
Youth is wasted on the young.
jimmyspeed
they should be well greased from the box but its worth checking them, moly/cv grease is what you would need
check the front top mount from through the bonnet when these go you'l get noise, but from what you say its more than likely the bearing.
phone up your local gsf and ecp and ask them to see what makes of bearing they have two good makes are SKF and FAG
E30REDD
How much did one wheel bearing cost you?daimlerman wrote:Front wheel bearings come as a complete hub unit,I buy mine from my local GSF.
About the brakes, I think they're from a 520.
harry_p
How many wheel bolts do your wheels use?
If its 4, it'll be a standard e30 bearing.
I doubt the disks are from a five series unless they've been redrilled or its running some strange setup.
cheers,
harry
harry
E30REDD
4 bolts yes.harry_p wrote:How many wheel bolts do your wheels use?
zd3bx
ECP sell front bearing kits, which come with a hub and the bearing already installed in it.
Get the one made by SNR, as they also sell one made by Orbis, which sounds like piece of sh1t based on the reviews I've read
E30REDD
Okay, exactly what is ECP?zd3bx wrote:ECP sell front bearing kits, which come with a hub and the bearing already installed in it.
Get the one made by SNR, as they also sell one made by Orbis, which sounds like piece of sh1t based on the reviews I've read.
Eurocarparts, but they have a sister company, Carparts4less, which is usually cheaper, depending on what fake sales ECP have going at the time.
zd3bx
Unbelievable, first time I hear about it...Brianmoooore wrote:Eurocarparts, but they have a sister company, Carparts4less, which is usually cheaper, depending on what fake sales ECP have going at the time.
Dodgy thing is, the prices displayed on CarParts4Less match the DISCOUNTED parts on ECP, meaning normally ECP charge 20-30% more for the same parts?
A simple example - I'm currently looking at a Sachs clutch kit, which is £121.20 on ECP with a 25% discount (due to bank holiday weekend), but normally it's £160.80....
Checked a few more parts and it's exactly the same story. Keep in mind, the parts are exactly the same on both sites.
What's the catch?
No catch whatsoever. Parts from CP4L come off the same shelves as those from ECP, are packed by the same people, and usually turn up in boxes taped up with ECP parcel tape.
Note that there are fixed extra discounts for orders of £50+, £75+ and £100+, so try to break up any big order into more than one order with totals as close to just over these amounts as possible.
Another thing to try, if you are spending less than £50, is to sign up to an account, make up a false order, place it in your 'basket' and then leave it at the 'checkout' overnight without paying.
The next day you will get an email giving you a discount code for 7.5% off on your next order. You then apply this discount to what you actually wanted to order in the first place.
zd3bx
Nice tip Brian
Also I realized that CP4L don't have any branches, so it's all online. I guess that's one of the main reasons for cheaper prices (or should I say non-inflated prices compared to ECP lol)
capnmchl
Plus CP4L is run by a bunch of about 4 retarded monkeys judging by my phone calls to them, but the low prices are worth the hassle if you get the wrong bit.
If you want to pay by credit/debit card CP4L will only deliver to the cardholders address - so if you need delivery to work forget it.
I understand you can get round this by paying by Paypal but I have yet to try it for myself.
ECP will deliver anywhere.
Grrrmachine
- E30 Zone Wiki / Team Member
All this talk of CP4L and ECP won't really help the OP, who lives in Sweden
CP4L deliver to Sweden via DHL for £17.95 for up to 25kg.
E30REDD
This is the cheapest alternative I've found so far: http://biltema.se/sv/Bil---MC/Bilreserv ... BMW-74118/
Translated:
Width [mm]: 40
Width [mm]: 61
Width 2 [mm]: 42
Width 2 [mm]: 62,5
Break dynamics: for vehicle with ABS
Break dynamics: for vehicle without ABS
Inner diameter [mm]: 31
Position: front axle
Position: Right
Position: Left
Additional information 2: with wheel hub
Weight [kg]: 1.370
Weight [kg]: 1.610
Outer diameter [mm]: 120
This would cost me 70 € including shipping.
Translated:
Width [mm]: 40
Width [mm]: 61
Width 2 [mm]: 42
Width 2 [mm]: 62,5
Position: Right
Position: Left
Weight [kg]: 1.370
Weight [kg]: 1.610
zd3bx
Not being funny, but it's a bit pointless asking where you can get bearings on a UK forum, when you live in Sweden.
Ask the mechanics/garages around your town and see where they get quality parts.
P.S. If you order the SNR front bearing kit from CarParts4Less.co.uk and get it delivered to Sweden, it will cost you roughly £80, which is around 95 EUR according to Google.
Not a bad deal, considering you get a decent part, if there aren't any available in your country.
E30REDD
I think they're taking an extreme over price for the products.zd3bx wrote:Not being funny, but it's a bit pointless asking where you can get bearings on a UK forum, when you live in Sweden.
Grrrmachine
A brand new FAG bearing is about 70 pounds over here, so it's not really worth trying to save 10 euros or so on a no-name brand.
E30REDD
I will order from CP4L but I have problems getting in touch with them. They don't answer on email nor in their live chat. Is this bad service a common problem with the company?
Rtaylor2208
Email is always slow on the reply and the chat never seems to work, but you can usually get through on the phone no problem.
Used them many times and not had an issue yet.
E30REDD
Do you get the gaskets when buying oil filters from CP4L?
Rtaylor2208
Gaskets? As far as I am aware there isn't one, just the rubber ring on the filter itself.
E30REDD
I have M42 so this is all parts I need when changing oil filter: https://www.google.com/url?sa=i&rct=j&q ... 8624768895Rtaylor2208 wrote:Gaskets? As far as I am aware there isn't one, just the rubber ring on the filter itself.
E30REDD
This is a very good answer, but in your post before this you mentioned "fake sales". What do you mean with that?Brianmoooore wrote:No catch whatsoever. Parts from CP4L come off the same shelves as those from ECP, are packed by the same people, and usually turn up in boxes taped up with ECP parcel tape.
TheDutch
Also worth looking at the Europe-wide http://www.mister-auto.se
E30REDD
I will stick to CP4L because they're cheaper on every part I need.TheDutch wrote:Also worth looking at the Europe-wide http://www.mister-auto.se
