Hey guys,
Will I damage an M20 starter by putting 12v across it straight from an external battery? Just want to check it engages properly with the ring gear before I start building everything else.
Test starter motor
macas
No problem at all doing it that way my friend
But you can't "check it engages properly with the ring gear" without bolting up a gearbox.macas wrote:No problem at all doing it that way my friend
Just applying power to the motor (inner large terminal) will just spin the motor. If you want to throw the pinion over as well, you need to connect power to the outer terminal and then short the medium sized terminal to it.
Motorhole
Thanks Brian, no worries. Yeah, it's already in the car, engine mated to gearbox etc. I just want to make sure I don't have any issues here requiring removal of engine & box before I sort out wiring, coolant, fit intake manifold etc.Brianmoooore wrote:
