Ive got a new belt and the tensioner
And i bought a spring load meter thingy like in the guide, when i bought it i made sure it was good enough for the correct tension. However someone has since removed the figure with (look in the haynes manual) out of the wiki
http://www.e30zone.net/e30zonewiki/inde ... elt_Change
So i need to know what tension i need on the meter thingy to have the tensioner adjusted correctly
Hope that makes sence
i dont have a haynes manual
Ive changed 2 m20 belts before and ive never bothered with timing tools just make sure nothing moves and the belt it lined up correctly in the teeth. I assume this method is fine with an m40
