m20 cam belt 10 years old but only done 11k miles
jimbom30cab
Tech 1 freak
Post Tue Apr 30, 2013 9:48 pm
i know everyone is going to say, change it to be on the safe side as that makes perfect sense so can't argue with that.
but although its 10 years old, it has only done 11k miles if the speedo has not been tampered with.
Is there a shelf life with these?
should i change it now do you think or risk it for a few months until the cab is back on the road??
ta
Jim320i
E30 Zone News / COTM Team
Post Tue Apr 30, 2013 9:52 pm
For the sake of £40 (That the price of a belt kit these days?) you may as well get it changed.
Isnt it recommended to change them every 4 years/40k? (Might be wrong)
jimbom30cab
Tech 1 freak
Post Tue Apr 30, 2013 9:53 pm
can't dissagree with that Jim, its just getting the time, i don't get much free time and i really want to get the cab back on the road for some topless fun !!
Post Tue Apr 30, 2013 10:14 pm
Depends if it's been sitting in one position for 10 years, or regularly turned over once in a while.
If it appears to be in good condition, then it's probably going to be OK for a while yet.
blondboy84
Post Tue Apr 30, 2013 10:15 pm
if you don't change it now, then at least don't drive it like you stole it :D on one of my ex cars my x-girlfriend broke the belt switching from first to second gear at about 6k rpm. cambelt was due to be changed in about 8k km (from 100k max life)
Astra bertone vert
mx5
1990 e30 325i SE+1990 e30 320i Touring
blondboy84
Post Tue Apr 30, 2013 10:17 pm
Speedtouch wrote:Depends if it's been sitting in one position for 10 years, or regularly turned over once in a while.
yeah, but you can't see micro tears on it.
material is old anyway.
as in the saying: Better safe, than sorry ;)
Astra bertone vert
mx5
Rtaylor2208
Post Tue Apr 30, 2013 10:25 pm
Jim I would change it. You would be raging if it breaks and what could have been £40 and 2 hours work turns into a rebuild.
Topblag
Post Tue Apr 30, 2013 10:26 pm
£40 quid and some spannering against £150 for another lump and a load more spannering. Add on another £90 in coolant, engine oil, another timing belt kit and sundries, at least and you're at £240.
The question is, do you feel lucky and is the £240 and a shed load of time and mess a big issue ?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Post Tue Apr 30, 2013 10:33 pm
Get it changed ASAP! No need to fit a 'kit' if one was fitted 11k miles ago. Bearings don't have a shelf life, but rubber does. Just change the belt.
Post Tue Apr 30, 2013 10:51 pm
I bought a car in 2009 with a rebuilt Fiat twin cam that had been sitting in a garage for a few years, and wondered/worried about the condition of the cambelt, but have been using it for 3 years now without any issues.
That said, I shall change it soon...
Rtaylor2208
Post Tue Apr 30, 2013 11:07 pm
Brianmoooore wrote:Get it changed ASAP! No need to fit a 'kit' if one was fitted 11k miles ago. Bearings don't have a shelf life, but rubber does. Just change the belt.
Brian is spot on about not being a kit. The belt is under £20 from CP4L and 5L coolant about £13 for 5 litres from a decent motor factors.
If it turns out when replacing the belt the pump needs done the circoli one on CP4L is a metal impeller and cheap and the tensioner can be had cheap enough.
Strangely enough the belt and tensioner are cheaper purchased seperatly than as a kit.
It's a bloody hateful job, but if you have done it before I reckon it can be done in about 2 hours which is about as long as it took me a few weeks back when doing the belt and pump and I'm definetly no mechanic.
Post Tue Apr 30, 2013 11:20 pm
Rtaylor2208 wrote: It's a bloody hateful job,
Hateful job? It's one of the easiest cam belts to change known to mankind! Would be easier still if the bonnet opened the conventional way.
Rtaylor2208
Post Tue Apr 30, 2013 11:25 pm
It's not particularly difficult, just not enjoyable without the bonet off and a ramp to make getting at bit from underneath easier.
mrLEE30
Post Wed May 01, 2013 7:02 am
belts even have a shelf life when they are on the shelf.
The ones I buy here in the middle East have a due date on the box, thus as Brian says the rubber has a finite life, less if stored incorrectly..or worse if stretched on the car...it could be feasible that the belt could last for another thirty years, it could break the next time you start it...and thus rings true of a brand new belt too, although warrrenties and consequntial dsmages apply here.
so yes for the sake of a few hours change the belt, the water pump and the tensioner.
TPS
Post Wed May 01, 2013 7:27 am
I echo everything that been said here, get it changed, as soon as humanly possible!
My M40 one broke, whilst waiting & a set of traffic lights, a week before it was booked in, for it to be changed, luckily I got away with just a new belt, and an ear bashing.
Post Wed May 01, 2013 1:43 pm
Mines 12 years old and done 10k or something
Its on the to do list :o:
**BANNED**
Post Wed May 01, 2013 2:03 pm
jimbom30cab wrote:i know everyone is going to say,
So why ask the question?
Every three years or 30k miles.
£10 for a belt
£1.5k for an engine re-build
Your choice!
Silverfang
Post Wed May 01, 2013 3:23 pm
Change the belt at least, Bearings do have a shelf life though as well as the grease in them can dry out after a few years (hence why they need changing) but only if they're regularly used
The belt though would have aged / cracked and could be a liabilty! as above, get it changed out asap, for the sake of £30 or so, better safe than spending 10 times that on a engine rebuild.
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
Post Wed May 01, 2013 3:36 pm
Jim. My car has done 1500 miles in 3 years. And it'll be getting a belt before it sees the road.
Its a no brainer. 10 years????
j4gz
Post Wed May 01, 2013 4:31 pm
I'm due to get mine done too it has also been ten years but I have been advised to also change the water pump too at the same time for the sake of £30 get them both done because I'm sure my mechanic goes you need o take it off to get to it I'm definatly doing both and costing about £250 for parts and labour .
broadie
Post Wed May 01, 2013 5:39 pm
I do mine at 5years regardless of what it is or mileage.
Carparts for less if you spend £100 "CP15LESS" will get you £15 off :wink:
jimbom30cab
Tech 1 freak
Post Thu May 02, 2013 8:53 am
right o, great advice, thanks
cam belt weekend fun coming up
:mad:
