evening all. im in a pickle lol.
ive got an 86' chromie with a m50 in. i did all the wiring ages ago and it was sweet..bht ive took it all kut and re routed it to make her look suave for show season. since ive put it al back in its now running a constant live...everything clicks on once the battery cable is on...with or without key. it starts on the key but it needs to be stalled out to kill it.
i should of madr note when removing the loom which wores went were but i thort theyd be straight forward..ie alternator, fusebox feed and starter go to the positive.
ideas welcome please.
ive tried unplugging the plug to the barrel but its the same, ive also tweeked the main positive bolt under the fuse pannel (inside the box) to attatch the charge wire[/quote]
constant live / hektic problems. please help
makman
its now fully dead and no lights.. mmm bump
Canny Beat a chromie!'
makman
bumppp please
If I could make sense of your OP, I'd try to help. If something is written in poor English without capitalisation and punctuation, I tend to move on to another post. I've only limited time on here, and I prefer to spend it unravelling technical problems rather than someone's poor English.
What exactly have you rewired and how?
