timing belt and water pump
j4gz
Post Mon Apr 29, 2013 6:19 pm
need advice please, i will be replacing the timing belt and at the same time get a new water pump fitted even though nothing is wrong with it as far as i know, just what the mechanic told me is the best thing to do .. pls can you tell me what the best oe parts to use and roughly how much should they charge to replace and fit the parts .....
Post Mon Apr 29, 2013 6:53 pm
KWP water pump
Contitech belt & tensioner kit
Available very reasonably from ECP or carparts4less
Not sure how much you're likely to pay for labour - may be 3-4 hours or so work ?
Post Mon Apr 29, 2013 7:15 pm
There are two electrical cables that run across the front of the timing belt cover, behind the water pump pulley. It's essential that these are retained in place properly by the guide and clips that hold them, otherwise they will wear through on the pulley.
Unfortunately the clips are often brittle and in need of replacement.
Post Mon Apr 29, 2013 7:27 pm
If its a facelift car you may also want to check the condition of the cooling system metal pipe that runs across the front of the engine - these commonly rot and are stupidly expensive from BMW IIRC Duke137 on here was selling a good powdercoated one recently.
