Auto shell and manual shell any difference ??
flashpat
Post Mon Apr 29, 2013 3:21 pm
I have found a mint rust free 318 auto shell (year 1987) with chrome bumpers and want to turn it into a 325i sport manual mtec 2(year 1990) .Can this be done ? is the tunnel the same?is there a difference in shell's pre face lift and face lift?
Steve
Post Mon Apr 29, 2013 3:55 pm
Your main problem will be the difference between pre facelift and the facelift shell not the auto / manual. You would be better off finding a facelift shell :D
Unless you're up for some bodywork :wink:
Quaser
Post Mon Apr 29, 2013 3:58 pm
afaik, its just mainly rear lights and front valance, and bumper mounts thats different -
ross_jsy
Post Mon Apr 29, 2013 4:12 pm
And the rear arches. Massive job to convert it and you will end up with a worthless kitted up bodged turd. Look for a facelift shell
capnmchl
Post Mon Apr 29, 2013 4:31 pm
Or make yours into a tech 1, which is better looking imo.
Or keep it as a chromie, which has more class about it than a tarted up rust bucket ;)
Post Mon Apr 29, 2013 4:37 pm
You'll need the following to convert it over to fit the Tech 2 kit.
Front lower valance
Rear complete light panel
Bottom rear qtr panels
Rear arches
Rear bumper mounts
Front bumper mounts
Post Mon Apr 29, 2013 7:26 pm
There's also a few other minor differences:
Spacing of prop. centre bearing mount holes (pre/post facelift difference)
Single horn mount under the grill instead of twin mounts under each wing (4 pot/6 pot difference).
Mounting bracket for clutch fluid reservoir (auto/manual difference).
Probably no ABS pump mountings on 318 shell (poverty spec./loaded up spec. difference).
broadie
Post Mon Apr 29, 2013 8:39 pm
Forget the tech and the 2.5. Go for a CR24v :cool:
ross_jsy
Post Mon Apr 29, 2013 9:44 pm
Cr24v is invite only don't you know
Post Mon Apr 29, 2013 9:51 pm
ross_jsy wrote:Cr24v is invite only don't you know
LOL, it don't exist any more either. :mad:
gooner1
Out humping Reindeer
Post Mon Apr 29, 2013 9:52 pm
Why would you want to de value a Chromie?
