rev counter and temp gauge not working
ramjam
Post Sun Apr 28, 2013 4:28 pm
Hello just started my1989 325 convertible today after 4-5 months i noticed the rev counter and temp guage not working it seems the right hand side of the cluster has gone dead could it be a easy fix? any ideas would be appreaciated
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Apr 28, 2013 5:02 pm
Post Sun Apr 28, 2013 7:48 pm
Wiki article doesn't make it clear, but if the tacho. and temp. gauge both start acting up at the same time, the most likely cause is SI board NiCd batteries, which have gone short circuit.
If the car has been left without a battery connected, or a flat battery for the time it's been laid up, then it's even more likely. The batteries may come back to life after a while, but they are faulty, and should be changed anyway.
Sanchez
Post Sun Apr 28, 2013 7:54 pm
Would this also be the case for speedo and mpg gauge?
Post Sun Apr 28, 2013 8:03 pm
Speedo isn't usually affected by the batteries. Speedo has it's own circuit board and electronics, well away from the rest of it.
ramjam
Post Sun Apr 28, 2013 9:00 pm
thanks for all the replys the battery was flat for a long time and the rev counter and temp guage broke at the same time ill try the batterys on the si board like brian said many thanks brian
blondboy84
Post Tue Apr 30, 2013 11:11 am
what could be wrong if, speedo and fuel level gauge stops working, but after restarting car it works again and than in a minute stops again. Then restarted the car and worked fine?
cheers
Astra bertone vert
mx5
1990 e30 325i SE+1990 e30 320i Touring
Post Tue Apr 30, 2013 1:33 pm
blondboy84 wrote:what could be wrong if, speedo and fuel level gauge stops working, but after restarting car it works again and than in a minute stops again. Then restarted the car and worked fine?
cheers
Sounds like some kind of problem with the power feeds from fuse 12 or 10. Any intermittent problems with the radio or reversing lights?
Try thumping the top of the dash to see if that affects the problem.
blondboy84
Post Tue Apr 30, 2013 3:57 pm
cheers
thanks - will try. Well anyway a have to install fresh dash, so will take everything apart-change those batts behind clocks.
will check what's with the fuses.
week ago battery was completely flat for no reasons at all. Was standing for some 10 days - battery drained flat... Some electric problems. What's about OBC - could it be somehow related? where does it take power from?
Astra bertone vert
mx5
Post Tue Apr 30, 2013 6:14 pm
OBC takes its power and most of its signals directly from the instrument cluster.
Is it acting up as well?
blondboy84
Post Tue Apr 30, 2013 10:26 pm
Brianmoooore wrote:OBC takes its power and most of its signals directly from the instrument cluster.
yep. Range doesn't work at all, mystical mileage, and it loses memory
I see, so it's the Nicd, Lion batteries behind the clocks are the ones to blame.
Astra bertone vert
mx5
Post Tue Apr 30, 2013 11:09 pm
Batteries on the SI board won't affect the OBC.
OBC memory loss also suggests a problem with the supplies from the fuses I've mentioned, and possibly fuse 21 as well.
blondboy84
Post Tue Apr 30, 2013 11:27 pm
ok,
thanks a lot.
Will try to find out what's wrong
ta.
Astra bertone vert
mx5
