My e30 has a leak from the matrix ? took it out this morning temp gauge went off the scale and wifey told me water was running onto the carpet and her leg,this then went to steam and facial sauna status.When i got back after letting the car cool and a top up,the carpet was soaked through.Removed the console and trim
and found a leak at the lowest point on the matrix,looks a git to remove.Any advise welcome,prior to this the heater was running cold for a long time,so i'm assuming the matrix is buggered.
Leaking heater Matrix... advise,
As a temporary work-around you can bypass the heater matrix by joining together the two pipes that go through the bulkhead with a piece of pipe. If you do this, mark the upper pipe so you don't mix them up when you reinstall them (after the heater matrix is fixed).
There's some stuff in the wiki about the heater matrix if you haven't seen it;
http://www.e30zone.net/e30zonewiki/inde ... oubleshoot
Good luck with sorting it out.
- Brianmoooore
Dealer every time! Stay away from unbranded ebay rubbish, which is often more expensive than the dealer anyway.
- Brianmoooore
Check that your radiator pressure cap has been changed under the 1997 recall.
http://www.e30zone.net/e30zonewiki/inde ... ting#Leaks
this may help a bit - if you hadn't seen it already
Removed the matrix yesterday,and there was a leak and the plastic heater box it lies in was full of coolant.Replaced it with a spare from a low mileage car ( mine has done 228,000 ) plumbed it back in and no leaks so far.Taking the glove box bracket out made things a lot easier putting the servo bracket back in place.
Mike.
Mike.
- Brianmoooore
Brianmoooore wrote:Check that your radiator pressure cap has been changed under the 1997 recall.
