Rear strut bushing doesn't fit because of a metal sleeve
E30REDD
Post Sat Apr 20, 2013 11:10 am
I'm changing my upper rear strut bushings.
This metal sleeve (to the left of the strut) was inside the old strut bushing:
https://www.dropbox.com/s/oeoxn8fv36hho ... 131136.jpg
https://www.dropbox.com/s/8imscy5afn0g9 ... 1119.jpg?m
It's impossible to get the metal sleeve inside the new strut because the strut bushing hole is too tight:
https://www.dropbox.com/s/cnwdn3xds6lvw ... 1054.jpg?m
If I remove the metal sleeve I can easily put the bushing in place, but I guess the metal sleeve has some functionality.
E30REDD
Post Sat Apr 20, 2013 11:15 am
I'm also wondering if this gasket is necesarry: http://i.ebayimg.com/t/BMW-Rear-Strut-T ... wWDUwMA==/$(KGrHqV,!oUFB0WPFMu5BQlQf6z9ew~~60_35.JPG
The old bushings doesn't have that gasket between the car and the bushing and there was no gasket included when I bought the new bushings.
gromgsxr
Post Sat Apr 20, 2013 1:32 pm
by the look the metal tube is part of the old bush and should still be attached to the center of the bush. new ones should have a part like that in the middle of the bush. gasket not sure my ones came with them get some gasket paper from a parts shop a few £ and cut it out easy
Post Sat Apr 20, 2013 1:37 pm
The metal sleeve is part of the old top mount - throw it away.
A new sleeve ( which might actually be barrel shaped, if you have upgraded to E46 cab. ones) is bonded into the new mount.
A gasket of some kind is necessary to stop water getting in, but I have used a little seam sealant as an alternative on the odd occasion.
E30REDD
Post Sun Apr 21, 2013 10:43 am
Just after I created this thread I realized where the metal sleeve came from. :D
Thank you for the answers tho!
