radiator is leaking
Rorym2010
just spotted a leak on the bottom of my radiator from the windscreen side its on the bottom left coming from a plug? thats threaded in shall I see if its fixable or just order a replacement?[/list]
Depends how bad the leak is; it may be fixable using something like this:
http://www.tesco.com/direct/evo-stik-pl ... tAodS04Avg
I recently had a punctured Morris Minor radiator repaired at a radiator repair specialist; they just used some epoxy resin such as Araldite, then pressure/leak-tested it, and gave it a lick of paint. Several months on, it's still working OK.
Rorym2010
does any one know if theres much difference between an air con rad and non air con rad as there is one on ebay says it fits a 316i with or without air con? cheers speed touch but my days of trying to bodge things are over always seems to come bite u in the associated later on
