IIRC they all part of the main engine harness.
All 3 of mine have worn badly due to the shat route the last guy who installed them took, so need to order replacements.
Question is what 3 wires are they?
1 is Crank position sensor
What to the other 2 do / control?
I'm not near the car so cant go out and look!
3 wires that route across the front of the block
Grrrmachine
- E30 Zone Wiki / Team Member
Crank Position Sensor
CID (Cylinder ID)
Oil Pressure Switch
CID (Cylinder ID)
Oil Pressure Switch
Cloggy Saint
Grrrmachine
Cloggy Saint
Only the oil pressure switch wire is part of the engine loom, and is only a single wire. Other two wires are part of the respective sensors.
