screeching after coolant,distributor and rotar arm change
iceox
Post Sat Mar 30, 2013 3:34 pm
just flushed coolant and changed thermostat, distruptor and rotar arm
so i emtied the lot, flushed it. then i put the bottom hose back on the radiator, turned the heater to full on hot and undone the bleed nipple. filled up the exspansion tank gave the hoses a few squizes and filled up tank again. then i started the engine, heared some screeches as if the water pump was dry and then it faded into a sorta dull screeching sound and it wont go away??
have i fooked the water pump?
cheers
BenHar
Post Sat Mar 30, 2013 4:21 pm
More likely that you've disturbed something so that it is rubbing on the belts or pulley.
Ben
iceox
Post Sat Mar 30, 2013 4:28 pm
did have a quick look but coudnt see any rubbing, i'll go have another look
cheers
bigwinn
Post Sat Mar 30, 2013 6:42 pm
is it a 325? When I did my first cam belt change I confused myself about the drive belt positioning- could it be in that area kind of screech?
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
iceox
Post Sat Mar 30, 2013 7:36 pm
just been out again and cant notice anything now?? good old e30's ay lol
cheers for the suggestion, i'll keep my ear on it
jimbom30cab
Tech 1 freak
Post Sat Mar 30, 2013 8:15 pm
LOL, joys of owning an old car hey.
Electrics are the worst, changing something simple is guarenteed to lead to hours of fault finding of unrelated new problems !!
