I know the fronts will fit in no problems, but can the rears be adapted to fit???
davetouring, we need you now!!
anyone else got any info or tips before I splash the hard earned?
Neil P
Fitting 2 door leathers to a touring..
320Touring
The seat base will just about fit but the back will need a bit of inventiveness.
320Touring
okBrianmoooore wrote:The seat base will just about fit but the back will need a bit of inventiveness.
Don't know, because I've used a saloon base in a touring as a temporary measure, but never tried a back.320Touring wrote:okBrianmoooore wrote:The seat base will just about fit but the back will need a bit of inventiveness.define "inventiveness"? are we talking custom made brackets etc?
You'll have to take the side bolsters out and remove the seat backs from their metal backplates and try a saloon back, but the two cars don't look very similar when they're stripped out
320Touring
ahah! time for a more thorough investigation, just as well I have 3 days off of work starting tomorrowBrianmoooore wrote:Don't know, because I've used a saloon base in a touring as a temporary measure, but never tried a back.320Touring wrote:okBrianmoooore wrote:The seat base will just about fit but the back will need a bit of inventiveness.define "inventiveness"? are we talking custom made brackets etc?
cheers!
ps does anyone know whether the ETK lists the brackets/pins for retaining the back of a touring seat as seperate parts (so they could be retro-fitted)?
