e28 diffs
320Touring
Post Sun Dec 04, 2005 11:53 am
As you folks are no doubt aware, I'm a tight git when it comes to the petrol costs of my touring :D
to this end, I've decided that the 4.10ish smallcase in my beast has got to go! the 3.5k at 70mph has to stop :cool:
I've been thinking of replacing it with a 2.97 diff from an e28 525e,if I can source one.
Now I know that thee28 LSD's are not a straight swap with the e30 ones, but are the open diffs interchangable?
If so, does anyone have one lying about for a reasonable price?
Neil P
OllieB
Post Sun Dec 04, 2005 11:57 am
I think maybe a 2.97 would make your gearing a bit too long, perhaps an E30 3.64 would be a better bet?
I'm too scared to drift properly......
320Touring
Post Sun Dec 04, 2005 12:09 pm
OllieB wrote:I think maybe a 2.97 would make your gearing a bit too long, perhaps an E30 3.64 would be a better bet?
I want it as long as possible, hence the 2.97, do a lot of motorway miles so accel is in 2nd place to cruising economically :D
Martinaston
Post Sun Dec 04, 2005 1:24 pm
with a 3.64 it will drink more juice around town, a lot more.
so you will have to be doing 1000's of motorway miles to make up for it, it's just not worth the bother :(
if your that tight then put an m40 1.8 in there and a smaller diff.
my old one was faster and more economical :mad:
there's no point in flogging a dead horse just because you like the sound of the exhaust :cry:
There is NO nucleus.
Templ8e30
Post Sun Dec 04, 2005 1:53 pm
In terms of fitting to E30's the E28 diffs (bar the M5 which won't fit) they all need the same treatment regardless of open/LSD internals.
You'll need a large case E30 cover plate and a pair of large case E30 output flanges.
I have a pair of output flanges spare if you need them.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Post Sun Dec 04, 2005 3:38 pm
As templ8e E30 says to get the E28 diff to fit, but you'll never get a 320 off the line with that diff. You'll need a new clutch once a month. A 325 would struggle with it.
I've got a 2.97 in my M50 touring, and it's just about right for that, with the 1:1 5th gear, and the other ratios pro ratio.
BrAdZ
Post Mon Dec 05, 2005 12:05 am
Argos wrote:Forget it. You wouldn't even get into fifth gear with a 320i. Every motorway hill you'd be down into fourth gear and flogging it to death, using loads of fuel.
3.64 is about as high as you can sensibly go - I did this on my 320i and although it improved the fuel consumption noticeably, it was on the limit in terms of driveability - fourth and fifth gear performance was a bit rank.
Early 320i's used a 3.45 diff but they also had 60 profile tyres.
agreed.... i had a 4.10 and went to a 3.64 and it would no longer light the wheels up in 2nd and 0-60 slowed quite a bit...... but then again i get better fuel consumption... i love it :P
exup
Boost Junkie
Post Mon Dec 05, 2005 10:44 am
Is it just a case of swopping the rear diff cover from an e30 to the e28 diff or more involved as i was considing the 2.97 for my 2.7 conversion as well
Post Tue Dec 06, 2005 12:03 am
exup wrote:Is it just a case of swopping the rear diff cover from an e30 to the e28 diff or more involved as i was considing the 2.97 for my 2.7 conversion as well
Swap rear cover and the drive flanges (just lever straight out)
Post Tue Dec 06, 2005 9:30 pm
Eyes read " 2.7 conversion" but my brain saw " M50 conversion".
Argos is right. 2.9 diff is OK with the E36/E34 gearbox, but no use with the M20 gearbox.
2.93 diff on E36/E34 box = 3.62 diff on M20 box
exup
Boost Junkie
Post Thu Dec 08, 2005 9:42 pm
Brianmoooore wrote:[
I 'M A BIT CONFUSED NOW ?
So , as i have a choice of e34 520 box&dif , e325 std box and 3.64 dif , i think i have a 325 sport g box ( how do you tell )
and 2.9 eta dif , or 320 box and diff,
i was thinking sport box and either 3.64 or 2.9 diffs to start with on a 2.7 eta running 325 cam and valves ported head + chip , ??
bottlecapE30
Post Sat Dec 10, 2005 4:55 am
I have a 2.97 with the right rear cover but the 5er output flages you could have it for $10 if you want to ship it from the US winkeye
