coilovers touching bodywork
sparkyE30
i bought a set of secont hand gaz gha coilovers and fitted the rears yesterday and they seem to be rubbing off the inside of the wheel arch.its the full coilover set up for the rear.i have the longer spacer on the inside against the trailing arm is this the correct way and i have the rose joint top mounts fitted aswell.any help would be appreciated.cheerz Mark
ajay
Are the rose jointed top mounts you are using offset top mounts? I seem to remember its quite important/necessary to use them for clearance.
sparkyE30
yes its the offset top mounts i am using
- E30 Zone Meets/Events Team
Pics would help.
milescook
Hi Mark get some pics up but have a gander at pics here
http://www.e30zone.net/modules.php?name ... 8&start=75
Just wondering, have you got all the spacers in? Are the offset mounts pushing the dampers away from the body rather than towards?
I really need offset mounts myself but on stilts setting and centred mounts I get only a little rub I so would have thought offset would cure it.
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
