I did quite a bit of research and assumed that my SI batteries needed replacing.
Symptoms:
Tacho didn't budge on first start in cold weather, problem has been slowly getting more frequent.
Couldn't reset SI lights easilly...only using wire bridging method at diag port.
Recently reset lights and within 2 days yellow and red lights were back on and 'Inspection' light illumined...'Oil Service' is not illumined...yet!
So I bought the batteries and dismantled the instrument cluster, soldering iron at the ready...nervously, then I found that it has the lithium batteries! The original Sanyo ones:
Do people think that the batteries are likely to be the problem? I stupidly didn't check the voltage...don't ask...either way, The batteries look a bit of a challenge to desolder and resolder on.
Is it easy enough you guys think?
Cheers!
