on the rear beam mount bushes that attach the subframe to the floor would you reuse the big washer that sits on top of the original bush when fitting the powerflex bushes.
http://www.realoem.com/bmw/showparts.do ... g=33&fg=30
part no 12 in pick
powerflex bushes
Rtaylor2208
Personally at £5 each I would. They will most likely be 20+ years old by now.
gromgsxr
i was more asking if you had to put the washers on with the powerflex bushes or not as the instructions dont mention them.
