Stuck lock on passenger door
scjimbo
Post Sat Mar 16, 2013 12:37 pm
I had the alarm taken out of my car about 6 months ago. Since then she's been wrapped up in the garage. The central locking has now ceased to function which isn't a massive issue to me. However the flaming passenger door is now stuck shut. Even using the key in the door doesn't work to unlock it. How do I go about getting the git open?
Cia
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Mar 16, 2013 1:33 pm
scjimbo
Post Sat Mar 16, 2013 2:45 pm
Awesome! Cheers grrrr. I was hoping someone could give me a method without taking all that off. :evil:
eko
Old timer
Post Sat Mar 16, 2013 2:52 pm
scjimbo wrote:Awesome! Cheers grrrr. I was hoping someone could give me a method without taking all that off. :evil:
You could try unlocking with the key while gently lifting the handle at the same time.
verde
Post Sat Mar 16, 2013 3:22 pm
Perhaps the microswitch is dead or goosed, it may have been pulled loose when the alarm was fiddled with. My drivers door wouldnt lock or unlock and I recently changed the microswitch and it works again
Raise hell praise Dale.
Grrrmachine
Post Sat Mar 16, 2013 4:10 pm
There is another system, but I'd wait for confirmation from Brian before trying it.
You need to take the kick panel off around the speaker in the driver's footwell, remove the speaker, and fish out the central locking relay. Disconnect the relay, and on the wiring plug find the lock/unlock wires. The aim is to give a quick 12V jolt to the actuators in the flow OPPOSITE to what they're used to - that's how you de-deadlock them.
I AM NOT supporting this method. I've done it on mine but I don't want to risk deadlocking all the acutators on your car, which is why I'm not going to mention the wire colours.
longwire
Post Fri May 03, 2013 11:11 pm
Hi if you havent managed to open you passengers door yet you could try this it worked for me.Wind down the window remove the plastic ring around the door pull you should now prise the cup off, with a pair of long nosed pliers ,grip the rod and pull sharply upwards as i said it worked give it try you may be luckie
