Heater blower packed up
Cloggy Saint
- **BANNED**
A good,almost free,starting point would be to remove the fan unit and oil it.
It's removed via an access hatch on the engine bay side of the bulkhead and some spring clips that will tax your patience and teach your next door's kids some new words!
Youth is wasted on the young.
- scallyally
If removing the fan to oil it as daimlerman suggests, put a pointy pin in the hole at the bottom of the retaining spring clip and lever it off. Simples
Rtaylor2208
The resistor is getting quite expensive for what it is from BMW. It was £16 last year and £24 when I bought one last week.
- **BANNED**
The clips come off quite easily,it's putting the little swine's back that causes the swearing!scallyally wrote:If removing the fan to oil it as daimlerman suggests, put a pointy pin in the hole at the bottom of the retaining spring clip and lever it off. Simples
- aimlessrock
+1.daimlerman wrote:The clips come off quite easily,it's putting the little swine's back that causes the swearing!scallyally wrote:If removing the fan to oil it as daimlerman suggests, put a pointy pin in the hole at the bottom of the retaining spring clip and lever it off. Simples
my hearter motor was in a poor state and I had to swallow for a new..
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
Cloggy Saint
Just checked the motor and it's spinning freely so that seems ok. Resistor next I guess, but as before, if it was knackered would the fan not work at all or just on the highest speed? Also, the wiki says where the resistor is on non AC cars but where is it on AC equipped models?
I've got AC on my E30, my resistor is under the blower motor.Cloggy Saint wrote:Just checked the motor and it's spinning freely so that seems ok. Resistor next I guess, but as before, if it was knackered would the fan not work at all or just on the highest speed? Also, the wiki says where the resistor is on non AC cars but where is it on AC equipped models?
1989 E30 325i Sport Auto
2003 E39 530d Sport Auto (Sold)
2012 F10 535i M Sport Auto
jonny323i
Iv been trying to figure that out as mine has ACMonkey27 wrote:I've got AC on my E30, my resistor is under the blower motor.Cloggy Saint wrote:Just checked the motor and it's spinning freely so that seems ok. Resistor next I guess, but as before, if it was knackered would the fan not work at all or just on the highest speed? Also, the wiki says where the resistor is on non AC cars but where is it on AC equipped models?
Touring for life
jonny323i
Touring for life
I found it somewhere on another forum the Bentley E30 Service Manual is very helpful. There is a link on here for an electronic versionjonny323i wrote:Iv been trying to figure that out as mine has ACMonkey27 wrote:I've got AC on my E30, my resistor is under the blower motor.Cloggy Saint wrote:Just checked the motor and it's spinning freely so that seems ok. Resistor next I guess, but as before, if it was knackered would the fan not work at all or just on the highest speed? Also, the wiki says where the resistor is on non AC cars but where is it on AC equipped models?
Cloggy Saint
- Brianmoooore
No, it's very unusual for the fuse to fail, since the stall current is barely enough to pop a 30A fuse.
What size fuse was there?
Cloggy Saint
- Brianmoooore
Take the thing out and lubricate it! Power it up while it's out and check that it runs freely.
I've only ever come across very few motors that can't be returned to as new performance with a bit of cleaning out and a drop or two of oil.
Cloggy Saint
Realoem does list 2 different part numbers for the blowers but doesn't mention anything about airco. I guess mine would be the more expensive one?macas wrote:If you decide to replace your blower,remember yours is a different size to a non aircon car,yours is slightly bigger....
