My 318is
virg18
Post Fri Dec 02, 2005 5:24 pm
Hi guys
I have a problem i have recently put G-Max 30mm lowering springs on my car and just been told that the springs are setting the camber angle out on the back, there for causing my tyres to blow out.
i've taken them off and been told that the camber angle can't be adjusted.
Is there any thing i can do. All suggestions would be helpful
thanx virg
TOURINGDADDY
Post Fri Dec 02, 2005 5:29 pm
the camber angle induced by -30mm springs will not cause your tyres to blow out! as for this cause i'd say faulty tyres or incorrect tyre pressure
E30Mark
Post Sat Dec 03, 2005 11:43 am
You can buy camber correcting bushes for the rear, they need to be installed by someone who knows what they are doing!
What do you mean by 'blow out' do you distort into a funny shape or risk physically blowing up??
PM for details
virg18
Post Mon Dec 05, 2005 5:06 pm
Thanx for the replies,
The actuall tyre on the inside wall burst on the rear passenger tyre and the wall of the rear drivers was creased inside again.
There were regal tyres 195/40/17 would this make a difference
Thanx again
virg18
Post Mon Dec 05, 2005 5:07 pm
Would you no where i could get camber bushes for the rear??
virg18
Post Fri Dec 16, 2005 5:35 pm
Hi guys do any one no where i can get bushes toadjust the rear camber angle
thanx
