inlet manifold
hexterman
Post Sun Mar 03, 2013 6:22 pm
can anyone tell me if all m20 inlet manifolds are the same
Post Sun Mar 03, 2013 6:23 pm
No, they differ form the B20 and B25.
hexterman
Post Sun Mar 03, 2013 6:33 pm
thanks i have a 320i do you know what the differance is
Jim320i
E30 Zone News / COTM Team
Post Sun Mar 03, 2013 6:34 pm
Shape, size, air flow... I have either for sale if you need one.
hexterman
Post Sun Mar 03, 2013 6:45 pm
thanks i just got one but not sure if its from a 325 or a320
Cloggy Saint
Post Sun Mar 03, 2013 6:54 pm
The inlet pipes on a b25 manifold are a smooth curve whereas on the b20 they have an angle on them.
hexterman
Post Sun Mar 03, 2013 6:58 pm
thanks i am off to check them thanks again for your help :)
Jim320i
Post Sun Mar 03, 2013 7:06 pm
Upload a picture if you are unsure, someone will be able to tell you straight the way when they see it
hexterman
Post Sun Mar 03, 2013 7:10 pm
looks like its off a 325i will it fit and run ok
Cloggy Saint
Post Sun Mar 03, 2013 7:13 pm
It will run ok but no better than ok. If you fit the 2.5 inlet manifold then you really should also use a 2.5 throttle body as the aperature is much larger on the 2.5 manifold. Likewise the ports on the 2.0 head are smaller so airflow will be disrupted. Hope that makes sense!
hexterman
Post Sun Mar 03, 2013 7:18 pm
thats a great help thanks again
