Adjustable roll bars.. which setting is stiffer?!
Fri Dec 02, 2005 2:50 pm
Trying to work it out in my head.. adjustable roll bars with different holes for different settings, which holes are for softer and which for stiffer settings?!
O O O
_____________
Crap pic but <-- That end gives the longer lever as it were
I hope someone understands what im saying :lol:
Got my front one on the middle hole, but the rear only has 2 and i'll be fitting it this w/end hopefully n want to know which hole is stiffer
HillclimbE30
Fri Dec 02, 2005 2:58 pm
The hole closer to the bar is the stiffer setting as less leverage on the transverse section, the further out from the bar you are hte longer the lever effect and hence softer the ARB is.
Hope this helps,
Fri Dec 02, 2005 3:00 pm
HillclimbE30 wrote:The hole closer to the bar is the stiffer setting as less leverage on the transverse section, the further out from the bar you are hte longer the lever effect and hence softer the ARB is.
Hope this helps,
Excellent cheers dude, thats what i thought it was, its the main bar that provides the stiffness so less leverage the more force needed to twist
