found 1 of my cylinder head spring (small) has broken M40
markus_74
Post Sat Mar 02, 2013 1:04 pm
Hello,
I found that my cylinder head spring of my m40 engine has broken while I open my engine.
the spring is the small one also the thin plate below the spring is break also.
does this cause my engine tremor when idle?
thank you
markus
markus_74
Post Sun Mar 03, 2013 12:50 pm
hello, willnz
the spring that is broken is small spring inside that I have give red circle also the round plate for the spring base has broken. see the picture below.
when I open my old engine block I found that there are No oil spray like that, all is vanished.
what is the result if my engine has run about 250.000km without this oil spray?
oil spray:
thank you
