petrol vaper smell sorted
gaszman
Post Sun Feb 17, 2013 8:16 am
i thought i would have a look remove rear bench and inspection cap and yes the large vaper hose from the filler neck fooked tried the cur of a bit job no good . so i thought i would just pull it out and fit a new one . not a chance can i ct the tube out remove the old hose and clean then tack weld it in again fit new hose .
Duke137
Post Sun Feb 17, 2013 8:35 am
I can't make head nor tale of what you wrote there! :?
gaszman
Post Sun Feb 17, 2013 8:39 am
the vent pipe to the little bottle behind the wheel goes through a pipe under the rear bench then goes behind the rear suspension leg . i cannot remove the old pipe from this pipe so if i cit it out the remove the pipe and then tac weld it back as its only a sleve .
**BANNED**
Post Sun Feb 17, 2013 8:58 am
The pipe cover within the wheel arch is little more than pressed tin.They mount using 4 black nylon 10mm nuts.New cover plates are available to order from your dealer and are not expensive.
If you need to replace the vent pipe,be seated when asking the price.It's an odd diameter that seems exclusive to this particular fitting.
Youth is wasted on the young.
gaszman
Post Sun Feb 17, 2013 9:00 am
not the bit within the wheel arch area the piece of pipe inder the rear seat area that connects to this section
**BANNED**
Post Sun Feb 17, 2013 9:03 am
All that has happened is that the outer of the pipe has stuck to the tube.Try twisting it from both ends until it comes free.
gaszman
Post Sun Feb 17, 2013 9:11 am
cant see the other end tank still in place going to do this anyway see what happens
**BANNED**
Post Sun Feb 17, 2013 9:14 am
Remove the o/s rear wheel and the cover plate,then you can attack the thing from both ends!
Some WD40 or similar will help to free it up,once you can move it,you will probably find enough slack to enable you to trim it's end...
gaszman
Post Sun Feb 17, 2013 9:29 am
have tried that mate yesterday have a new pipe but i cannot get the old one out do not wont to remove the tank
you cannot get any where near the end under the tank
gaszman
Post Sun Feb 17, 2013 9:36 am
this pipe / tube is nuder the rear seat it carries the vent pipe from the filler neck to the tank also hase two smaller pipes inside it also . both also vent pipes . going to cut it out the way clean it our then t6ack it back sorted
hope this is clear now
Post Sun Feb 17, 2013 10:08 am
The above reads as if you are going to cut the steel pipe out, then weld it back in. That is not a good idea, or remotely necessary!
The three vent pipes are taped together along their length, so all three need to be removed as one. Disconnect them through the tank hatch, tape a piece of rope to the longest one, and pull them all out together under the wheel arch. Feed the hoses back one at a time, starting with the large rubber one, using the rope to guide them in.
gaszman
Post Sun Feb 17, 2013 11:14 am
all done brian the pipe is rusting from the inside so i will get one fabricarted as you can see from the pic
no thats not surface rust
