Coops90
Post
Sat Feb 16, 2013 1:41 pm
This little shitbag won't come off. Anyone got any ideas? Been whacking it which things for a few hours. I dont have a set of bearing pullers either
Cheers chaps.
maggspower
- Turbo Farmer Tractor Driver
Post
Sat Feb 16, 2013 1:45 pm
A little bit of heat and some levers, screwdrivers and hammers (small ones).
Post
Sat Feb 16, 2013 1:49 pm
In theory, a simultaneous whack from each side with two large hammers should crack it off.
- **BANNED**
Post
Sat Feb 16, 2013 2:09 pm
A suitable bearing puller will soon shift that.
Youth is wasted on the young.
BATTS91
Post
Sat Feb 16, 2013 6:08 pm
What willnz said !
Post
Sat Feb 16, 2013 6:09 pm
Or, degrease it and use Mole Grips to twist it off.
harry_p
Post
Sat Feb 16, 2013 8:16 pm
I used a slide hammer with a hooked end to get that bit off when I did one on my e36.
If you have nothing at all to lever it off with I'd very carefully attack it with a grinder.
cheers,
harry
mcbonio
Post
Sat Feb 16, 2013 8:34 pm
Buy a cheap 3 leg puller for a couple of quid, will be off in seconds.
BATTS91
Post
Sat Feb 16, 2013 10:49 pm
Air grinder ive found is the best , very small thin disc and controlable ish speed
HairyScreech
Post
Sun Feb 17, 2013 1:46 am
Bit of heat and a tap will see that moving no trouble.
Coops90
Post
Mon Feb 18, 2013 7:08 pm
Mega, nice one chaps. Done now.
Malachite uber alles
capnmchl
Post
Mon Feb 18, 2013 7:16 pm
What method did you use?
