Leaks are one obvious thing & if they don't re-extend, or they feel generally rough or slack then that's got to be a fair giveaway I know.
Is it ok for them to make any noise though, or should they be silent?
was playing about with some ford scrote ones at college last night, they're gas and oil..Ziggy wrote:I only ask cos I got some M3 front shocks off eGay, & want to be certain they're ok before I use em!
Anyone know about the noise? Cheers
the fluid moves through a very small hole, hence the resistance, at worst should only hear it very quietly when held at your ear and pushed, but if at arms length should be quietZiggy wrote:Cheers...
Basically they feel fine, but you can definately hear the gas / oil / whatever, moving inside...Has something leaked to where it shouldn't be?
Yup that makes perfect sense, but these ones certainly aren't *that* bad!sabrje wrote:Took some knackered ones off my car. When I compressed them there was little or no resistance and then they took an age to fully extend again (if at all). There was plenty of resistance in the new good ones and they extended pretty quickly. Does that make sense?
That's what my brand new rears were like, but the fronts sound like there are some li'l bubbles in there or something...320Touring wrote: the fluid moves through a very small hole, hence the resistance, at worst should only hear it very quietly when held at your ear and pushed, but if at arms length should be quiet
There's plenty of resistance & they return fine - it's just the fact that they're not silent like my new rears, that worried me...Simon wrote:They sound OK to me, as has been said, when pushed down, there should be good resistance, and shoud return fully (make sure you don't have to help it out fully).
Are they worth much then!?
I threw a pair of 5000km old ones out about a month ago!!
Well I suppose he is a *reasonably* knowledgable kinda chap...320Touring wrote:well, if the m3 man says they sound ok, then that'd do for me
I can't be that knowledgable...I threw my good ones away!!Ziggy wrote:Well I suppose he is a *reasonably* knowledgable kinda chap...320Touring wrote:well, if the m3 man says they sound ok, then that'd do for me![]()
Is that the general consensus then; they'll be fine?
Simon wrote: I can't be that knowledgable...I threw my good ones away!!
They sound ok to me, they all make some noise when damping.
