Trying to remove rear beam bushes in situ HELP!
OOjoeE30
Sun Feb 10, 2013 12:34 pm
Trying to get the rear beam bushes out, I havent got the tool to draw them out so have been attacking it with a drill, jigsaw, chisel , hacksaw blades etc. The center of the bush stayed on the car when I dropped the beam down slightly so that isnt the problem its just the ridiculously strong outer sleeve.
Any suggestions I havent thought of or shall I just persist.
threelander
Sun Feb 10, 2013 12:45 pm
have you tried burning them out
OOjoeE30
Sun Feb 10, 2013 1:16 pm
Not going to do that while its still on the car, I'm not having trouble with the rubber, its the outer sleeve which sits in the beam i'm having trouble manipulating
craigieeb
Sun Feb 10, 2013 1:20 pm
OOjoeE30 wrote:problem its just the ridiculously strong outer sleeve.
Just drop the beam,
the time you've been messing around on your back, fighting with the bushes,
you could of had the beam down, bushes out and new ones in
OOjoeE30
Sun Feb 10, 2013 2:33 pm
Its got the better of me for now, tools were thrown its raining I'm now inside lol will be getting the train for the week.
Is there anywhere I can rent the tool from?
Sanchez
Sun Feb 10, 2013 2:54 pm
do you have a 3 legged puller?
OOjoeE30
Sun Feb 10, 2013 4:03 pm
I dont, would it be worthwhile picking one up? I have looked at some guides where they have been used do you seat it on the subframe and then use a large washer to draw it through?
milescook
Sun Feb 10, 2013 4:16 pm
I jigsawed through the metal sleeve carefully on opposite sides.thing is how are you getting the new bushes in? I think if you don't have the tool its easiest to take it off, give it to a garage with a press will rake them 10 mins
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
tomislav
Sun Feb 10, 2013 4:22 pm
Get the rear axle of the car completely then either a) burn them out (there is a very thin layer of rubber between the metal casing and axle which will free up nicely once hot enough) or b) cut thro the casing in two places and hammer out
telski789
Sun Feb 10, 2013 4:23 pm
i used an air chisel to cut them
OOjoeE30
Tue Feb 19, 2013 6:32 pm
Ended up dropping everything out at the week and replaced all the bushes its now back together, brakes bled, diff fluid changed, I wont be attempting something like that again on my own.
tomislav
Tue Feb 19, 2013 6:36 pm
You enjoyed that then lol.
Its done now at least.
