Recently bought my first E30 and a couple of days in I noticed the o/s headlight bulb was out so thought I would change it (it did work prior to noticing it had blown) anyway, changed the H1 bulb and now the damn thing won't work at all! The sidelights work fine, has to the high beam on both sides but only the low beam works on the n/s now ant not the side I've changed. The bulb is fine as I've checked it works by putting it in the other side and seeing it illuminate. There doesn't seem to be any fuses blown and the wiring all looks ok. So just wondering of anyone could suggest anything? I was thinking a relay maybe? But not sure about how these work so pretty much stumped.
Any advice would be greatly appreciated people! Thanks
