how to change the master clutch cylinder
aceifty
Post Mon Feb 04, 2013 11:18 am
Iv got a 325 cab and i like to know how to change the master clutch cylinder. [/list]
**BANNED**
Post Mon Feb 04, 2013 12:27 pm
Remove the under dash panel on the driver's side :mad:
Unbolt the pedal from the master cylinder
Open the bonnet :mad:
Unbolt the pipe that feeds the slave cylinder
Remove the master cylinder from the pedal box,using lots of swearing as you struggle to get a tool onto the 8mm bolts that retain it.
Apologise to 'er next door for teaching 'er kids several interesting words.
Note;
You will almost certainly need a new 'connector' to fit between the master and it's feed,these are dealer only,but cost a couple of £,but will take two days to arrive.
Youth is wasted on the young.
Motorhole
Post Mon Feb 04, 2013 1:25 pm
Don't forget to bleed the system first unless you want to deal with 500 ml of nasty brake fluid all over your drivers footwell and driveway :) Undo the bleed nipple on the slave cylinder, loosen the cap on the fluid reservoir under the bonnet. Attach a pipe to the bleed nipple running into a jar or other suitable container and keep pumping the clutch pedal until nothing is coming out.
...and don't forget to refill once you've replaced the m/s :)
Post Mon Feb 04, 2013 1:47 pm
I wouldn't attempt this job without removing the driver's seat. Your back will thank you.
aceifty
Post Mon Feb 04, 2013 2:24 pm
Thanks for the help
