LSD Oil?
hazd31
What do I need and how much do I need? thanks in advance
BenHar
maggspower
- Turbo Farmer Tractor Driver
Castrol syntrax. 1.7L
When doing the job, undo the filling hole first. You could imagine the problem undoing the drain hole then not being able to undo the fill plug.
Grrrmachine
- E30 Zone Wiki / Team Member
Andyboy
- Alpina Colada
Use nothing but Castrol SAF-XJ as recommended by BMW. Your local BMW dealer may sell you a couple of litres.
maxfield
I believe it's now changed to syntrax now Andy, used to be SAF-XJAndyboy wrote:Use nothing but Castrol SAF-XJ as recommended by BMW. Your local BMW dealer may sell you a couple of litres.
