hello, after got engine block crack and oil pump house, I decided to find complete engine block complete set with oil pump etc but still use my old top engine and old oil pan.
my question does e36 m40 318i engine is exact same with e30 m40 318i engine? of course I know the oil pan is different so I will use my old oil pan.
I found the piston diameter is different and the piston rod at e36 m40 engine is short compare to e30 m40 engine. does is it better?
any one here know what is other else different? oil house pump etc same or not?
thank you for the info
markus
Can I use my e30 m40 cylinder head to e36 m40 cylinder block
markus_74
markus_74
hello willnz
no it is same 1.8.
does output shaft from e36 cranksaft will fit into my old e30 transmission? because I see at the realoem catalog that it has different transmission between e30 and e36.
so I assume that it will not fit?
need info
no it is same 1.8.
need info
markus_74
how about engine mounting? does is it same or not?
I have check that output shaft from the info I got it is same, so compatible with e30 transmission.
Jos
You can swap the mounts over from the e30 M40 if you need to.
'94 e36 tree climber
markus_74
hello, Jos
so basically it is no problem to use engine from e36 m40 to e30 m40 and it is plug and play with transmission, ecu, etc
how about piston compression does is it same 1:8.8 or higher?
does the ignition controled by ecu will be same? or will be different?
Thank you
Thank you
Jos
I know it will fit, that's about it, the M40/M42 from the e30/e36 all share the same block.
Why not just fit the whole engine and ECU? Head change means new gaskets and headbolts. Loom change has got to be easier?
Andyboy
- Alpina Colada
The E36 engine has a different cambelt tensioner (big toothed one) to the pre 1991 E30. Just swap the sump, loom, mounts and possibly exhaust manifold and fit the whole engine.
markus_74
hello, thank you all zoner member here for the input, so I can decided to get original e30 cylinder block to replace mine that is crack.
