Tyre pressures
jimbob29
Mon Jan 28, 2013 11:33 am
Can someone tell me the correct front and rear tyre pressures on standard 15 bbs 7j rims on a 320i please??
torquey
Mon Jan 28, 2013 7:36 pm
i`m running kumho ecstas on the same size rims and the tyre fitters put 29lb in all round,
BHadley
Mon Jan 28, 2013 8:44 pm
If you pass on your reg and tyre size I can check on tech data on work computer
FinalD
Mon Jan 28, 2013 8:57 pm
Reg shouldn't matter? They will be 205/55 R15 as he is running normal BBS wheels, I read about online and the general consensus was 31-36PSI....helpful. I've gone (for now) with the default of 32PSI as it is what I chuck into most of my cars unless otherwise instructed by a manual. :D
BHadley
Mon Jan 28, 2013 9:15 pm
Sounds about right, hand book says 34psi for the front and 32 psi for the rear (2.1 & 2.3 bar)
